Api event user set user data
API Endpoint: api/event/user/set_user_data/
Description: Update the values for the given user.
| 0 | OPTIONAL | (String) | Domain Name (optional, leave empty by default) | |
| 1 | REQUIRED | (String) | Username | |
| 2 | REQUIRED | (String) | Nickname | |
| 3 | REQUIRED | (String) | First name | |
| 4 | REQUIRED | (String) | Last name | |
| 5 | REQUIRED | (String) | Phone number | |
| 6 | REQUIRED | (Enumeration) | User access level | DOMAIN_ADMIN, EDITOR, HOST_SESSION, JOIN_ONLY, NONE or SUPER_USER |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/event/user/set_user_data/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ "", "Username", "Nickname", "First name", "Last name", "Phone number", "NONE" ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
body: '[ "", "Username", "Nickname", "First name", "Last name", "Phone number", "NONE" ]'
fetch("https://engine.tygron.com/api/event/user/set_user_data/", options)
