Api event user get log
Revision as of 14:50, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/user/get_log/ Description: Get a specific log. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | OPTIONAL | (String) | Domain Name (optional, leave empty by default) | |- | 1 | REQUIRED | (Enumeration) | Type | BACKUP, JOBS, LOGINS, SECURITY, SESSIONS or USERS |- | 2 | REQUIRED | (String) | Log Token | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 200 | Log (Log) |- | 300-600 | Codes Overv...")
0 OPTIONAL (String) Domain Name (optional, leave empty by default)
1 REQUIRED (Enumeration) Type BACKUP, JOBS, LOGINS, SECURITY, SESSIONS or USERS
2 REQUIRED (String) Log Token
200 Log (Log)
curl 'https://engine.tygron.com/api/event/user/get_log/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ "", "SESSIONS", "Log Token" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: '[ "", "SESSIONS", "Log Token" ]'
fetch("https://engine.tygron.com/api/event/user/get_log/", options)
