Api event user get domain user names
Revision as of 14:50, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/user/get_domain_user_names/ Description: Get the names of users in the Domain. {|class=wikitable !Index !Importance !Type !Description !Values |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 200 | String[] (String array) |- | 300-600 | Codes Overview |} ===Example POST=== Curl example POST <syntaxhighlight lang="text" copy>curl 'https://engine.tygron.com/api/event/user/get_domain_user_names/' -H 'Content-Type: applica...")
200 String[] (String array)
curl 'https://engine.tygron.com/api/event/user/get_domain_user_names/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d ''
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: ''
fetch("https://engine.tygron.com/api/event/user/get_domain_user_names/", options)
