Api event io set project template
API Endpoint: api/event/io/set_project_template/
Description: Set whether a specified Project is a template, marking it as a Project to base other Projects on.
| 0 | REQUIRED | (String) | Project Name | |
| 1 | REQUIRED | (true, false) | Whether the Project is a template | true or false |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/event/io/set_project_template/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ "Project Name", true ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
body: '[ "Project Name", true ]'
fetch("https://engine.tygron.com/api/event/io/set_project_template/", options)
