Api event io set project sub domain
Revision as of 14:49, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/io/set_project_sub_domain/ Description: Set a Project to be available to a sub Domain of the Domain the Project is currently in. A Subdomain can only access this Project if this property matches the name of the Subdomain exactly. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (String) | Project Name | |- | 1 | REQUIRED | (String) | Subdomain name | |} ===Response Codes=== {|class=wikitable !Response Code: !...")
0 REQUIRED (String) Project Name
1 REQUIRED (String) Subdomain name
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/io/set_project_sub_domain/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ "Project Name", "Subdomain name" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: '[ "Project Name", "Subdomain name" ]'
fetch("https://engine.tygron.com/api/event/io/set_project_sub_domain/", options)
