How to interact with a popup
Revision as of 10:00, 18 November 2026 by Server@tygron.com (talk | contribs)
A popup panel to send a request to the municipality for a permit for the construction of offices.
You begin interacting with a popup by clicking on a popup in the 3D Visualization. This will open the Popup info panel. The popup panel will inform you of the action that is currently pending. Depending on the pending action, you may be prompted to provide input about the action. You finish your interaction with the popup panel by using the buttons at the bottom right of the panel. Usually, there will be two buttons. One button confirms or approves the action, while the other denies or cancels it. If you are not yet ready to confirm or deny the action, you can also click the "cross" at the top right of the popup panel, or the "close" button at the bottom left of the popup panel.
 Interacting with a popup:
  1. Click on a popup to open the popup panel.
  2. If necessary, enter the information requested by the popup panel.
  3. Finish interaction using the buttons at the bottom right corner of the popup panel.
