Api session items netnodes
Revision as of 10:20, 13 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/netnodes/
Edit items with events described at Api session event editor netnode.
Default Query:
https://engine.tygron.com/api/session/items/netnodes/?token=API_TOKEN
Example Response:
  "connectedLineIDs" : [ 0 ],
  "id" : 0,
  "loadIDs" : [ 0 ],
  "name" : "NetNode 0",
  "point" : {
    "type" : "Point",
    "coordinates" : [ 659045.3750031103, 6798911.888461599, 47.75 ]
  "sourceIDs" : [ ],
  "version" : 11
  "connectedLineIDs" : [ 0, 12, 123 ],
  "id" : 1,
  "loadIDs" : [ ],
  "name" : "NetNode 1",
  "point" : {
    "type" : "Point",
    "coordinates" : [ 659077.8577249872, 6798911.888461599, 39.432 ]
  "sourceIDs" : [ ],
  "version" : 12
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/netnodes/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/netnodes/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/netnodes/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/netnodes/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/netnodes/?crs=LOCAL&token=API_TOKEN
Bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/netnodes/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/net_nodes-foo/?crs=3857&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/netnodes/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/netnodes/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/netnodes/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/netnodes/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/netnodes/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/netnodes/?f=JSON&token=API_TOKEN
GEOJSON:
https://engine.tygron.com/api/session/items/netnodes/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/netnodes/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/netnodes/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/netnodes/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/netnodes/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/netnodes/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/netnodes/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/netnodes/?f=ZIPSMILE&token=API_TOKEN
Api Model NetNode
API Model description of NetNode
Name Type Description
connectedLineIDs int[]
id int
loadIDs int[]
name String
point Point Point
sourceIDs int[] Sources ID
version int
Api Model Point
API Model description of Point
type String Point
coordinates double[] x, y, (optional) z
