Api session event participant popup answer with date
Revision as of 14:55, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/participant/popup_answer_with_date/
Description: Stakeholder answers a Popup with an additional date
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (POPUP Integer ID) Popup
2 REQUIRED (Integer number) Answer ID
3 REQUIRED (Integer number) Time in milliseconds long from epoch
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/popup_answer_with_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1, 64 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/participant/popup_answer_with_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1, 25 ]'
JavaScript example POST
 body: '[ 1, 1, 1, 64 ]'
fetch("https://engine.tygron.com/api/session/event/participant/popup_answer_with_date/", options)
