Api session event participant money transfer give
Revision as of 14:55, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/participant/money_transfer_give/
Description: Stakeholder transfers money to another Stakeholder
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder (seller)
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder (receiver)
2 REQUIRED (Enumeration) Type of transfer LAND, SUBSIDY or TRANSFER
3 REQUIRED (String) Transfer Message
4 REQUIRED (Floating point number) Amount
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/money_transfer_give/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "SUBSIDY", "Transfer Message", 42 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/participant/money_transfer_give/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "SUBSIDY", "Transfer Message", 9 ]'
JavaScript example POST
 body: '[ 1, 1, "SUBSIDY", "Transfer Message", 42 ]'
fetch("https://engine.tygron.com/api/session/event/participant/money_transfer_give/", options)
