Api session event participant measure plan construction
Revision as of 14:55, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/participant/measure_plan_construction/
Description: Stakeholder plans a Measure
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (MEASURE Integer ID) Measure
200 Integer (Action Log ID)
curl 'https://engine.tygron.com/api/session/event/participant/measure_plan_construction/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/participant/measure_plan_construction/", options)
