Api session event logic zone set attribute
Revision as of 14:55, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/zone_set_attribute/
Description: Set an Attribute for a Zone
0 REQUIRED (ZONE Integer ID) Zone
1 REQUIRED (String) Attribute
2 REQUIRED (Floating point number) Value
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/zone_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute", 12 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/zone_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute", 44 ]'
JavaScript example POST
 body: '[ 1, "Attribute", 12 ]'
fetch("https://engine.tygron.com/api/session/event/logic/zone_set_attribute/", options)
