Api session event logic set traffic multiplier
Revision as of 14:55, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/set_traffic_multiplier/
Description: Multiply the visual traffic density by a factor
0 REQUIRED (Floating point number) Factor
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/set_traffic_multiplier/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '4.0'
JavaScript example POST
 body: '4.0'
fetch("https://engine.tygron.com/api/session/event/logic/set_traffic_multiplier/", options)
