Api session event logic scenario set active
Revision as of 14:55, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/scenario_set_active/
Description: Activate a Scenario
0 REQUIRED (SCENARIO Integer ID) Scenario
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/scenario_set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/logic/scenario_set_active/", options)
