Api session event logic net cluster set load attributes
API Endpoint: api/session/event/logic/net_cluster_set_load_attributes/
Description: For each Net Load of a Net Cluster, set the values of the provided Attributes
| 0 | REQUIRED | (NET_CLUSTER Integer ID) | Net Cluster | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attributes | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Array with values |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_load_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute 1", 1.0 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_load_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ "Attribute 1", "Attribute 2", "Attribute 3" ], [ 1.0, 2.0, 3.0 ] ]'JavaScript example POST
body: '[ 1, "Attribute 1", 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_cluster_set_load_attributes/", options)
