Api session event logic measurement set sum
Revision as of 14:55, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/measurement_set_sum/
Description: Set a Measurement to add its base Overlays to itself
0 REQUIRED (MEASUREMENT Integer ID) Measurement
1 REQUIRED (true, false) Add base Overlays true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/measurement_set_sum/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_set_sum/", options)
