Api session event logic dismiss error
Revision as of 14:55, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/dismiss_error/
Description: Dismiss an Error Log
0 REQUIRED (ERROR_LOG Integer ID or multiple integer values in array [1, 2, 3]) Error Logs
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/dismiss_error/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/dismiss_error/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/logic/dismiss_error/", options)
