Api session event logic cinematic stakeholder start
API Endpoint: api/session/event/logic/cinematic_stakeholder_start/
Description: Start a Cinematic for a Stakeholder
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 1 | REQUIRED | (CINEMATIC_DATA Integer ID) | Cinematic Data | |
| 2 | REQUIRED | (true, false) | Animate to Cinematic starting Point | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/cinematic_stakeholder_start/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'JavaScript example POST
body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/cinematic_stakeholder_start/", options)
