Api session event answer upgrade zoning permit denied
API Endpoint: api/session/event/answer/upgrade_zoning_permit_denied/
Description: Stakeholder's planned Upgrade is denied based on zoning
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 1 | REQUIRED | (BUILDING Integer ID) | Building |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/answer/upgrade_zoning_permit_denied/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/answer/upgrade_zoning_permit_denied/", options)
