Api session event editor zoning set permitter
Revision as of 14:55, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorzoning/set_permitter/
Description: Set the permitting Stakeholder of a Zone
0 REQUIRED (ZONE Integer ID) Zone
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder (permit issuer)
200 Boolean (Updated)
curl 'https://engine.tygron.com/api/session/event/editorzoning/set_permitter/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorzoning/set_permitter/", options)
