Api session event editor zoning remove
Revision as of 14:55, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorzoning/remove/
Description: Remove a Zone, and optionally its child Zones
0 REQUIRED (ZONE Integer ID or multiple integer values in array [1, 2, 3]) Zones
1 REQUIRED (true, false) Remove Children true or false
200 Boolean (Removed)
curl 'https://engine.tygron.com/api/session/event/editorzoning/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorzoning/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], true ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorzoning/remove/", options)
