Api session event editor trigger set url
Revision as of 14:55, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editortrigger/set_url/
Description: Add the URL of a Trigger
0 REQUIRED (TRIGGER Integer ID or multiple integer values in array [1, 2, 3]) Triggers
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) URLs
204 No Content
curl 'https://engine.tygron.com/api/session/event/editortrigger/set_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "URL 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editortrigger/set_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "URL 1", "URL 2", "URL 3" ] ]'
JavaScript example POST
 body: '[ 1, "URL 1" ]'
fetch("https://engine.tygron.com/api/session/event/editortrigger/set_url/", options)
