Api session event editor time set start date
API Endpoint: api/session/event/editortime/set_start_date/
Description: Set the start date and Time of a Project, as milliseconds from Epoch
| 0 | REQUIRED | (Integer number) | Milliseconds since 00:00:00 UTC on 1 January 1970 |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editortime/set_start_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '20'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editortime/set_start_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '75'JavaScript example POST
body: '20'
fetch("https://engine.tygron.com/api/session/event/editortime/set_start_date/", options)
