Api session event editor overlay set show difference
Revision as of 14:54, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_show_difference/
Description: Set whether a Grid Overlay has a difference option. If an Overlay has a difference option, an addition output is available computed from the difference between the CURRENT and MAQUETTE outputs
0 REQUIRED (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) Grid Overlays
1 REQUIRED (Boolean or multiple boolean values in array [true, false, true]) Has a difference option (false means there is no difference option for this Overlay)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_show_difference/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_show_difference/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_show_difference/", options)
