Api session event editor overlay set service force xy
Revision as of 14:54, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_service_force_xy/
Description: Set the preferred option to force the CRS order to longitude/latitude for the Service Source of a specified Service Overlay
0 REQUIRED (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) Overlays (WMS or WCS)
1 REQUIRED (Boolean or multiple boolean values in array [true, false, true]) Longitude first (force XY)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_service_force_xy/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_service_force_xy/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_service_force_xy/", options)
