Api session event editor overlay set overlay source
API Endpoint: api/session/event/editoroverlay/set_overlay_source/
Description: Add or remove specific Sources to or from a Source Overlay
| 0 | REQUIRED | (OVERLAY Integer ID) | Source Overlay | |
| 1 | REQUIRED | (SOURCE Integer ID or multiple integer values in array [1, 2, 3]) | Sources | |
| 2 | REQUIRED | (true, false) | Add to the Overlay (false removes the Sources from the Overlay) | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_source/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_source/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], true ]'JavaScript example POST
body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_source/", options)
