Api session event editor overlay set overlay image
API Endpoint: api/session/event/editoroverlay/set_overlay_image/
Description: Change the image displayed by an Image Overlay
| 0 | REQUIRED | (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) | Image Overlays | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"] or matrix [["a", "b"], ["c", "d"], ["e", "f"]]) | Image Names |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ "A1", "B1" ] ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ [ "A1", "B1" ], [ "A2", "B2" ], [ "A3", "B3" ] ] ]'JavaScript example POST
body: '[ 1, [ "A1", "B1" ] ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_image/", options)
