Api session event editor overlay set neural network
Revision as of 14:54, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_neural_network/
Description: Set the Neural Network for an Inference Overlay
0 REQUIRED (OVERLAY Integer ID) Inference Overlay
1 REQUIRED (NEURAL_NETWORK Integer ID) Neural Network
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_neural_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_neural_network/", options)
