Api session event editor overlay set net overlay
API Endpoint: api/session/event/editoroverlay/set_net_overlay/
Description: Set the visualization style for a Network Overlay
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay (Network Ownership or Network Overview) | |
| 1 | REQUIRED | (Enumeration) | Net Type | ELECTRICITY, GAS, HEAT, INTERNET or SEWER |
| 2 | REQUIRED | (true, false) | Whether to show the network | true or false |
| 3 | REQUIRED | (true, false) | Whether only active connections should be visualized (false means both active and inactive connections are visualized) | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_net_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "ELECTRICITY", true, true ]'JavaScript example POST
body: '[ 1, "ELECTRICITY", true, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_net_overlay/", options)
