Api session event editor overlay set difference entry name
API Endpoint: api/session/event/editoroverlay/set_difference_entry_name/
Description: Set the name of an entry of an Overlay's difference legend
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay | |
| 1 | REQUIRED | (Integer number) | Entry ID | |
| 2 | REQUIRED | (String) | Name |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_difference_entry_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Name" ]'JavaScript example POST
body: '[ 1, 1, "Name" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_difference_entry_name/", options)
