Api session event editor overlay set custom legend
API Endpoint: api/session/event/editoroverlay/set_custom_legend/
Description: Set whether an Overlay has a custom legend. If set to false, its legends are reverted to a generated default
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay | |
| 1 | REQUIRED | (true, false) | Has a custom legend | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_custom_legend/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'JavaScript example POST
body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_custom_legend/", options)
