Api session event editor overlay set combo formula
API Endpoint: api/session/event/editoroverlay/set_combo_formula/
Description: Set formula for a Combo Overlay
| 0 | REQUIRED | (OVERLAY Integer ID) | Combo Overlay | |
| 1 | REQUIRED | (String) | Formula |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_combo_formula/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Formula" ]'JavaScript example POST
body: '[ 1, "Formula" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_combo_formula/", options)
