Api session event editor overlay remove difference entry
API Endpoint: api/session/event/editoroverlay/remove_difference_entry/
Description: Remove entries from an Overlay's difference legend
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay | |
| 1 | REQUIRED | (Integer number or multiple integer values in array [1, 2, 3]) | Entry IDs |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_difference_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_difference_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/remove_difference_entry/", options)
