Api session event editor overlay add
Revision as of 14:52, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/add/
Description: Add a new Overlay of the specified type
0 REQUIRED (Enumeration) Overlay Type INFERENCE, AREA, ATTRIBUTE, AVG, COMBO, DISTANCE, FLOODING, FUNCTION, GEO_TIFF, GROUNDWATER, HEAT_STRESS, HEIGHTMAP, IMAGE, ITERATION, LIVABILITY, MUNICIPALITIES, NEIGHBORHOODS, NETWORK_DISTANCE, NETWORK_OVERVIEW, NETWORK_OWNERSHIP, OWNERSHIP, OWNERSHIP_GRID, RAINFALL, RESULT_CHILD, SATELLITE, SCENARIO, SHADOW, SIGHT_DISTANCE, SOURCE, TEST, TRAFFIC_DENSITY, TRAFFIC_NO2, TRAFFIC_NOISE, TRAVEL_DISTANCE, UNDERGROUND, WATERSHED, WCS, WMS, ZIP_CODES or ZONING
200 Integer (Overlay ID)
curl 'https://engine.tygron.com/api/session/event/editoroverlay/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"OWNERSHIP"'
JavaScript example POST
 body: '"OWNERSHIP"'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/add/", options)
