Api session event editor netcluster generate clusters
Revision as of 14:52, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetcluster/generate_clusters/
Description: Generate Net Clusters for a set of Net Types, using a Clustering Type, a Region, allowed owners of Buildings, cluster area size, default Stakeholder for created Net Clusters. A default Stakeholder for Net Loads without an associated Building. A Cluster Attribute and optional specific value can be used to only include specific Net Loads. Optionally, Net Loads identified as Collective can be clustered separately
0 REQUIRED (NetType or multiple values in array [a, b, c]) Net Types
1 REQUIRED (Enumeration) Clustering Type ADD_TO_EXISTING_FOR_BUILDINGS, MAP_SECTORS, PER_ATTRIBUTE, PER_BUILDING, PER_LOAD or PER_LOAD_UNIQUE_OWNER
2 REQUIRED (MultiPolygon with crs: EPSG:3857) Region
3 REQUIRED (STAKEHOLDER Integer ID or multiple integer values in array [1, 2, 3]) Stakeholders (allowed Building owners)
4 REQUIRED (Floating point number) Cluster area size
5 REQUIRED (STAKEHOLDER Integer ID) Stakeholder (default Cluster owner)
6 REQUIRED (String) Cluster Attribute
7 REQUIRED (true, false) Cluster Collective Loads Separately true or false
8 OPTIONAL (Floating point number) Specific Cluster Attribute Value
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetcluster/generate_clusters/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ "ELECTRICITY", "PER_LOAD", {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 1, 41, 1, "Cluster Attribute", true ]
Curl example multi item POST
[ [ "ELECTRICITY", "GAS", "HEAT" ], "PER_LOAD", {
}, [ 1, 2, 3 ], 60, 1, "Cluster Attribute", true ]
JavaScript example POST
 body: '[ "ELECTRICITY", "PER_LOAD", { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, 1, 41, 1, "Cluster Attribute", true ]'
fetch("https://engine.tygron.com/api/session/event/editornetcluster/generate_clusters/?crs=3857", options)
