Api session event editor measure set levee height
Revision as of 14:52, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editormeasure/set_levee_height/
Description: Set the inner height of a Levee Spatial of a Measure
0 REQUIRED (MEASURE Integer ID) Measure
1 REQUIRED (Integer number) Levee Spatial ID
2 OPTIONAL (Floating point number) Height value
204 No Content
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_levee_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_levee_height/", options)
