Api session event editor measure set geotiff
Revision as of 14:51, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editormeasure/set_geotiff/
Description: Change the GeoTIFFs applied by a specified Measure
0 REQUIRED (MEASURE Integer ID) Measure
1 REQUIRED (Integer number) GeoTIFF Spatial ID
2 REQUIRED (GEO_TIFF Integer ID or multiple integer values in array [1, 2, 3]) GeoTIFFs
204 No Content
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_geotiff/", options)
