Api session event editor measure set event
Revision as of 14:51, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editormeasure/set_event/
Description: Change an pre-existing event of a specific Action Type of a Measure
0 REQUIRED (MEASURE Integer ID or multiple integer values in array [1, 2, 3]) Measures
1 REQUIRED (Boolean or multiple boolean values in array [true, false, true]) Server Side (false = Client Side)
2 REQUIRED (ActionType or multiple values in array [a, b, c]) Action Types
3 REQUIRED (CodedEvent or multiple values in array [a, b, c]) CodedEvents
204 No Content
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, true, "CONSTRUCTION_PLAN", {
 "id" : -1,
 "parameters" : [ ]
Curl example multi item POST
[ [ 1, 2, 3 ], [ true, false, true ], [ "CONSTRUCTION_PLAN", "CONSTRUCTION_PLAN_CANCEL", "CONSTRUCTION_PLAN_CANCEL" ], [ {
 "id" : -1,
 "parameters" : [ ]
 "id" : -1,
 "parameters" : [ ]
 "id" : -1,
 "parameters" : [ ]
JavaScript example POST
 body: '[ 1, true, "CONSTRUCTION_PLAN", { "id" : -1, "parameters" : [ ]} ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_event/", options)
