Api session event editor measure add levee
API Endpoint: api/session/event/editormeasure/add_levee/
Description: Add a new Levee Spatial of a specified Levee to a Measure
| 0 | REQUIRED | (MEASURE Integer ID) | Measure | |
| 1 | REQUIRED | (LEVEE Integer ID) | Levee |
| 200 | Integer (Levee Spatial ID) |
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_levee/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add_levee/", options)
