Api session event editor cinematic set keypoint orientation
Revision as of 14:51, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorcinematic/set_keypoint_orientation/
Description: Set the camera location, orientation and lookat of a Key Point in 3D Visualization coordinates (X is east, Y is up, Z is south)
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic Data
1 REQUIRED (Integer number) Key Point ID
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Camera Location
3 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Up Vector
4 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Lookat location
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_orientation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1.0, 1.0, 1.0 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_orientation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST
 body: '[ 1, 1, 1.0, 1.0, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_orientation/", options)
