Api session event editor chat set neural network
Revision as of 14:51, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorchat/set_neural_network/
Description: Set the LLM Neural Network for the Channel
0 REQUIRED (CHAT_CHANNEL Integer ID or multiple integer values in array [1, 2, 3]) Chat Channels
1 REQUIRED (NEURAL_NETWORK Integer ID or multiple integer values in array [1, 2, 3]) Neural Networks (type LLM)
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editorchat/set_neural_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorchat/set_neural_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorchat/set_neural_network/", options)
