Api session event editor chat reset
Revision as of 14:51, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorchat/reset/
Description: Reset a Chat Channel's content
0 REQUIRED (CHAT_CHANNEL Integer ID or multiple integer values in array [1, 2, 3]) Chat Channels
200 Boolean (Returns true if the channel was found and messages were removed, otherwise false)
curl 'https://engine.tygron.com/api/session/event/editorchat/reset/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorchat/reset/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorchat/reset/", options)
