Api session event editor building multi select
Revision as of 14:51, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorbuilding/multi_select/
Description: Change the Function of multiple Buildings. Optionally adjust the floors (>0). Optionally merge the Buildings into one
0 REQUIRED (FUNCTION Integer ID) Function
1 REQUIRED (Integer number) Floors
2 REQUIRED (true, false) Merge true or false
3 REQUIRED (BUILDING Integer ID or multiple integer values in array [1, 2, 3]) Buildings
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorbuilding/multi_select/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorbuilding/multi_select/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true, [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1, true, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/multi_select/", options)
