Api session event editor building generate rotation angles
API Endpoint: api/session/event/editorbuilding/generate_rotation_angles/
Description: Calculate a rotation angle for Buildings with Polygons for the identifying Attribute, optionally only for specified Buildings
| 0 | REQUIRED | (String) | Identifying Attribute | |
| 1 | REQUIRED | (String) | Rotation Attribute | |
| 2 | OPTIONAL | (BUILDING Integer ID or multiple integer values in array [1, 2, 3]) | Buildings (optional) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorbuilding/generate_rotation_angles/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Identifying Attribute", "Rotation Attribute" ]'JavaScript example POST
body: '[ "Identifying Attribute", "Rotation Attribute" ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/generate_rotation_angles/", options)
