Api session event participant popup answer
API Endpoint: api/session/event/participant/popup_answer/
Description: Stakeholder answers a Popup.
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 1 | REQUIRED | (POPUP Integer ID) | Popup | |
| 2 | REQUIRED | (Integer number) | Answer ID |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/participant/popup_answer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'JavaScript example POST
body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/participant/popup_answer/", options)
