Api session event participant panel answer
Revision as of 08:37, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/participant/panel_answer/
Description: Stakeholder selects an Answer in a Panel.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (PANEL Integer ID) Panel
2 REQUIRED (Integer number) Answer ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/panel_answer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/participant/panel_answer/", options)
