Api session items heights
Revision as of 16:05, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/heights/
Edit items with events described at Api session event editor map.
Default Query:
https://engine.tygron.com/api/session/items/heights/?token=API_TOKEN
Example Response:
  "id" : 0,
  "name" : "1",
  "pointAreaM2" : 16.0,
  "pointWidth" : [ 125, 0 ],
  "sourceIDs" : [ 8 ],
  "square" : {
    "type" : "MultiPolygon",
    "coordinates" : [ [ [ [ 657093.832562376, 6800274.005242179 ], [ 657093.832562376, 6799461.8964563515 ], [ 657905.9006092999, 6799461.8964563515 ], [ 657905.9006092999, 6800274.005242179 ], [ 657093.832562376, 6800274.005242179 ] ] ] ]
  "version" : 6
  "id" : 1,
  "name" : "2",
  "square" : {
    "coordinates" : [ [ [ [ 657905.9006092999, 6800274.005242179 ], [ 657905.9006092999, 6799461.8964563515 ], [ 658717.9686562237, 6799461.8964563515 ], [ 658717.9686562237, 6800274.005242179 ], [ 657905.9006092999, 6800274.005242179 ] ] ] ]
  "version" : 7
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/heights/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/heights/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/heights/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/heights/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/heights/?crs=LOCAL&token=API_TOKEN
Bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/heights/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/heights-foo/?crs=3857&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/heights/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/heights/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/heights/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/heights/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/heights/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/heights/?f=JSON&token=API_TOKEN
GEOJSON:
https://engine.tygron.com/api/session/items/heights/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/heights/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/heights/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/heights/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/heights/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/heights/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/heights/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/heights/?f=ZIPSMILE&token=API_TOKEN
Api Model GeometryCollection
API Model description of GeometryCollection
Name Type Description
Api Model HeightSector
API Model description of HeightSector
changed Boolean
envelope Envelope
id int
name String
pointAreaM2 double
pointWidth int[]
sourceIDs int[] Sources ID
square MultiPolygon MultiPolygon
version int
Api Model MultiPolygon
API Model description of MultiPolygon
type String MultiPolygon
coordinates double[][][][] array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z]
