Api session event editor neuralnetwork set neural network
API Endpoint: api/session/event/editorneuralnetwork/set_neural_network/
Description: Set the RCNN for a Neural Network via a byte array of a Open Neural Network Exchange
| 0 | REQUIRED | (NEURAL_NETWORK Integer ID) | Neural Network | |
| 1 | REQUIRED | (byte or multiple values in array [a, b, c]) | Byte array content | |
| 2 | REQUIRED | (String) | Uploader Name |
| 200 | Neural Network ID |
curl 'https://engine.tygron.com/api/session/event/editorneuralnetwork/set_neural_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Uploader Name" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorneuralnetwork/set_neural_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], "Uploader Name" ]'JavaScript example POST
body: '[ 1, 1, "Uploader Name" ]'
fetch("https://engine.tygron.com/api/session/event/editorneuralnetwork/set_neural_network/", options)
