Api session event editor actionmenu swap order
API Endpoint: api/session/event/editoractionmenu/swap_order/
Description: Swap the order of paired Action Menus
| 0 | REQUIRED | (ACTION_MENU Integer ID or multiple integer values in array [1, 2, 3]) | Action Menus (main) | |
| 1 | REQUIRED | (ACTION_MENU Integer ID or multiple integer values in array [1, 2, 3]) | Action Menus (other) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoractionmenu/swap_order/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoractionmenu/swap_order/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoractionmenu/swap_order/", options)
