Api session event editor cinematic set keypoint time
API Endpoint: api/session/event/editorcinematic/set_keypoint_time/
Description: Set the time it takes to move from the specified Key Point of a Cinematic to the next
| 0 | REQUIRED | (CINEMATIC_DATA Integer ID) | Cinematic Data | |
| 1 | REQUIRED | (Integer number) | Key Point ID | |
| 2 | REQUIRED | (Floating point number) | time in seconds |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 38 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 7 ]'JavaScript example POST
body: '[ 1, 1, 38 ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_time/", options)
