Api session event editor cinematic remove keypoint event bundle
API Endpoint: api/session/event/editorcinematic/remove_keypoint_event_bundle/
Description: Remove an Event Bundle from a Key Point of a Cinematic
| 0 | REQUIRED | (CINEMATIC_DATA Integer ID or multiple integer values in array [1, 2, 3]) | Cinematic Datas | |
| 1 | REQUIRED | (Integer number or multiple integer values in array [1, 2, 3]) | Key Point IDs | |
| 2 | REQUIRED | (Integer number or multiple integer values in array [1, 2, 3]) | Event Bundles |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorcinematic/remove_keypoint_event_bundle/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorcinematic/remove_keypoint_event_bundle/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ 1, 2, 3 ] ]'JavaScript example POST
body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/remove_keypoint_event_bundle/", options)
